License problem with AMESim
I have a problem with my student license. When I try to start the program the following error message appears "Failed to connect to the license server". How can i solve my problem?
Thank you in advance!
Michele
Re: License problem with AMESim
Hi Michele,
one question upfront:
Are you using LMS Amesim within an Educational Bundle or have you downloaded the LMS Amesim Student Edition?
Eric
I've downloaded the LMS Amesim Student Edition
Siemens Genius Siemens Genius
Siemens Genius
Hi Michele,
I supposed you have the LMS_LICENSE environment variable set. Probably because you had also another license of LMS Imagine.Lab Amesim on your machine.
Can you check it?
If this environment variable is set, try to unset it and to restart the LMS Imagine.Lab Amesim.
Kind regards
Thank you for your support, the license now works properly
I am also facing some installation issue. Can somebody tell me how to create a new request in PLM Community. I am not getting that option. I can only see others questions.
Hi Sachin14,
if you go to "Forum - 1D Simulation Solutions" you'll see the "Start a Discussion" button. (Yellow circled in the screenshot below)
There you'll start a new topic.
Please have a look if another post already answers your question.
Thank you,
Eric
