Save Plot with user defined scales
mAx 1st Gear
1st Gear
I was wondering if it is possible to save a plot with specific scaled and configurations in the system, to call it later with same config.
For intance I have a chart with x-axis zoomed between 2 and 3 sec and 4 displayed variables on 4 separated y-axis.
If I save it in my system (right icon on AMEPlot), and recall it, I loose my x-zoom (it switched again in autoscale mode) and the 4 variables will be displayed on the same y-axis
I am running V14.0 version of AMESim.
Thanks for any tip
Maxime
Re: Save Plot with user defined scales
Hi @mAx,
I just tried to reproduce the scenario you're describing, and was able to save a plot configuration (zoomed in X-axis + 4 separate axes) without any issues in my own copy of v14.0.
Can you provide more information about the global workflow you're following, where you end up with a plot that isn't correctly saved?
Thanks!
-Karim
mAx 1st Gear
1st Gear
Hello @knassar,
I tried again this morning and it worked.
I don't know why I couldn't before.
Anyway thank you
