Water demper
Hello, scientists!
Did i modele this water demper properly? I am goint to use it in pipe chain for damping pulsation at pipes acoustic frequensy.
Re: Water demper
Hi Vitalii,
the modeling seems good. You can also simply use the accumulator models included into the Hydraulic library.
A demo model is available in Demos\Librairies\Hydraulic\Anti pulsating accumulator.
