the executable of the system cannot be found or is out of date!
When i try to open a model in my colleage system , i am getting this error messsage.
"the executable of the system cannot be found or is out of date!"
Please just me how to resolve this issue.
Re: the executable of the system cannot be found or is out of date!
Hello SriniS,
Are you using Amerun to open the model?
If you are, your colleague needs to have gone into Simulation mode in Amesim in order to compile the model.
Then you would be able to open and run it in Amerun.
If you are using Amesim, I'm not sure what is going on and I advise you get in touch with GTAC to raise an incident request. See this post for details about using GTAC.
