Is there a special tool required for switching between different LMS Amesim versions?
Community Manager
Question:
Answer:
In $AME/misc you will find a RunAMESimTemplate.bat which should allow you to run specific LMS Amesim versions.
You need to edit that bat file to specify the path of the current version.
If that still fails, please use GTAC to raise an Incident Report.
If that works, you can copy a shortcut to this bat file on your Desktop and rename it to "Amesim xx"
Contributors
