[Tips & tricks] - How to go faster using LMS Imagine.Lab Amesim starters
Siemens Enthusiast Siemens Enthusiast
Siemens Enthusiast
LMS Amesim starters are the templates which help you improve modeling efficiency and enable knowledge sharing.
How can you use LMS Amesim starters?
  • Reuse standard LMS Amesim demos: they are great sources of information on LMS Amesim libraries, platform facilities and industry-oriented solutions.
  • Reuse off-the-shelf libraries starters to make sure that material properties are properly defined in your system.
  • Create your own template: for example, a standard layout with your company name and project information.
  • Combine several starters to create a new model.
Want to know more? Watch the video.
(view in My Videos)
Contributors
