cancel
Top 10 analyses to run with LMS Amesim engine models and how to choose the most suitable one
Siemens Visionary Siemens Visionary
Siemens Visionary
Thanks to its long history and expertise in the engine modeling area, LMS Imagine.Lab Amesim allows to model an internal combustion engine in many different ways, depending on the goals ...
We are used to talk about the scalability of LMS Amesim, but it goes way beyond this single word and we could say that the only purpose of this capability is to satisfy user’s needs.
Indeed, there are so many needs when it comes to engine modeling, and so many ways to model an engine in LMS Amesim, that without guidance, the user could choose an inappropriate submodel with the associated unwanted effects.
Here is a non-exhaustive list of the numerous ways a 4-cylinders engine model can be modeled, which user’s needs it satisfies and some hints about which one to choose based on several relative criterion.
#1 - Assessing the thermal behavior of an engine cooling and/or lubrication circuit
The engine is a heat source and can be modeled using the following libraries and components:
  • The Signal, Thermal and thermal hydraulic libraries components
Simple LMS Amesim engine model for heat releaseSimple LMS Amesim engine model for heat release
  • Or the Cooling system library component
                                       Simple LMS Amesim engine model for heat release and cooling system designSimple LMS Amesim engine model for heat release and cooling system designHeat release LMS Amesim mapHeat release LMS Amesim map
  • Or the IFP-Drive library components
           IFP-Drive engine model for heat releaseIFP-Drive engine model for heat releaseIFP-Drive engine model configuration for heat release computationIFP-Drive engine model configuration for heat release computation
  • Or the IFP-Engine library components (mean value engine model or high frequency engine model)
Detailed engine model for heat release in LMS AmesimDetailed engine model for heat release in LMS Amesim
Capabilities summary
#2 - Assessing the fluid flow behavior of an engine cooling and/or lubrication circuit
The engine is a fluid volume with restrictions and can be modeled using the following libraries and components:
  • The Signal, Thermal & Thermal Hydraulic libraries components
Engine fluid flow LMS Amesim modelEngine fluid flow LMS Amesim model
  • Or the Cooling System library components
Engine fluid flow simple LMS Amesim modelEngine fluid flow simple LMS Amesim model
  • Or the CAD import tool combined with Thermal and Thermal Hydraulic libraries components
(view in My Videos)
#3 - Driving a pump, an alternator, a shaft or a power take-off
The engine is a torque/rotational speed source and can be modeled using the following libraries and components:
  • The Signal and Mechanical libraries components
LMS Amesim torque or speed generation modelLMS Amesim torque or speed generation model
  • Or the Powertrain library components
LMS Amesim simple engine torque modelLMS Amesim simple engine torque model
  • Or the IFP-Engine library components using a mean value engine model (MVEM)
LMS Amesim mean value engine modelLMS Amesim mean value engine model
#4 - Assessing the fuel consumption of the vehicle over a driving cycle
The engine consumes fuel to drive the vehicle and can be modeled using the following libraries and components
  • The IFP-Drive library components
  • Or the IFP-Engine library components using a Mean Value Engine Model (MVEM)
LMS Amesim Mean Value Engine modelLMS Amesim Mean Value Engine model
  • Or the IFP-Engine library components using a high frequency engine model
Detailed engine model for fuel consumption simulation in LMS AmesimDetailed engine model for fuel consumption simulation in LMS Amesim
#5 - Validating the Engine Control System
The engine, its actuators and sensors are compatible with real-time control units and can be modeled using:
  • IFP-Engine library components with MVEM
MVEM engine model for control system design and V&VMVEM engine model for control system design and V&V
  • Or with high frequency engine model
Engine model for control system design and V&VEngine model for control system design and V&V
#6 - Assessing the crankshaft torsional vibrations induced by the combustion
The engine is a harmonics generator and can be modeled using the following libraries and components:
  • The Powertrain library components
LMS Amesim engine model for NVH analysisLMS Amesim engine model for NVH analysis
LMS Amesim detailed engine model for NVH analysisLMS Amesim detailed engine model for NVH analysis
#7 - Assessing the ride comfort and vehicle drivability
The engine is a 3D dynamic mass with 6 degrees of freedom and can be modeled using:
LMS Amesim engine model for ride comfort and drivability analysisLMS Amesim engine model for ride comfort and drivability analysis
(view in My Videos)
 #8 - Assessing the engine bearings lubrication
The engine is a reciprocating force source and can be modeled using the following libraries and components:
  • The Planar Mechanical library components
Engine model for bearings lubrication designEngine model for bearings lubrication design
LMS Amesim engine model for bearings designLMS Amesim engine model for bearings design
#9 - Assessing the exhaust after-treatment system efficiency
The engine is an exhaust gases generator and can be modeled using the following libraries and components:
  • The Signal library components
Simple engine exhaust gases LMS Amesim modelSimple engine exhaust gases LMS Amesim model
LMS Amesim engine model for exhaust gases analysisLMS Amesim engine model for exhaust gases analysis
  • Or the IFP-Engine library components using MVEM
 LMS Amesim MVEM engine model for exhaust gases generationLMS Amesim MVEM engine model for exhaust gases generation
  • Or the high frequency engine model
LMS Amesim IFP-Engine model for pollutants analysisLMS Amesim IFP-Engine model for pollutants analysis
#10 - Assessing the engine air intake, exhaust and fuel systems performances
The engine converts air and fuel into exhaust gases, torque and heat and can be modeled using the following libraries and components:
  • The IFP-Engine library components with MVEM
 LMS Amesim MVEM engine model for air and fuel loops designLMS Amesim MVEM engine model for air and fuel loops design
  • Or the CFD 1D and IFP-Engine libraries components
LMS Amesim detailed engine model for air and fuel loops designLMS Amesim detailed engine model for air and fuel loops design
Bonus (coming in rev 16) - Assessing the vehicle underhood thermal behavior
The engine is a radiative and convective heat source and will be modeled using the HEAT library components:
LMS Amesim engine model for underhood thermal analysisLMS Amesim engine model for underhood thermal analysisLMS Amesim HEAT underhood cooling stack analysisLMS Amesim HEAT underhood cooling stack analysis
 For more information please visit our website
Comments
Hello Roman,
Thanks for putting together this overview of the top 10 engine modeling scenarios.  Do you happen to have actual models for these that you can share?  I'd like to use these examples as a learnig tool/mechanism.  I'm sure others will find it beneficial.
Thanks!!
Siemens Visionary
Hi Allegheny,
LMS Amesim demo helpLMS Amesim demo helpMany models covering all these scenarios are available in the LMS Amesim Demo Help (Except for the bonus scenario that will arrive in rev16).
In addition to the actual models, you always find the explanation of scenarios and what are the capabilities of the model!
Let us know if you miss some scenarios, we are always keen to furnish this demo base.
Romain
Siemens Enthusiast Siemens Enthusiast
Siemens Enthusiast
nice example of scalability and multiphysics modeling within LMS Amesim!
