3D composite Solid laminate display bug?
I turned ON the feature to display elemental ID, Prop, Matl info from View Options for 3D composite solid laminate. The ID & property values correspond correctly to the ones that I expect. However the material value is being displayed incorrectly. I have checked multiple times in my layup definition as well as 3D solid laminate definition. In both entries, I have selected the correct material.
Could this be a bug? Just letting Femap folks know if it is one.
