ANSYS APDL file to FEMAP?
Is there any way to import an APDL (Ansys Parametric Design Language) analysis file into FEMAP?
Krisu
Re: ANSYS APDL file to FEMAP?
If you add a CDWRIT command to the end of your APDL, you can get ANSYS to write out a file that FEMAP can import.
Problem is that I dont have an ANSYS license (only ANSYS AQWA). AVEVA creates the APDL format from a 3D cad model. So far AVEVA is not able to create NASTRAN output.
-Kristoffer
You will have to ask the ANSYS user  to output the mesh via the ANSYS CDWRIT command and provide you with that file.
