API Control Entity Visibility of Properties
Hi
I am trying to use the following command for dynamically control the properties by using Femap 10.0.2
    App.feEntityVisibility (FVIS_PROP, p2set.ID, False, True)
Observing the following error in Femap
Basic Error (Line 32, Offset 0): (10091) ActiveX Automation: no such property or method
is this Activex supported in Femap 10.0.2, any alternative to use this
srini
Re: Control Entity Visibility of Properties feEntityVisibility - API
It appears that method was added in FEMAP 10.1.0, next version after 10.0.2.
You could use Groups instead. Ex:
Sub Main
    Dim App As femap.model
    Set App = feFemap()
    Dim p2set As Set
    Dim g As Group
    Dim v As View, viewID As Long
    Set p2set = App.feSet
    Set g = App.feGroup
    Set v = App.feView
    App.feAppGetActiveView(viewID)
    v.Get(viewID)
    p2set.AddRange(1,2,1)
    gID = g.NextEmptyID()
    g.SetAdd(FT_PROP,p2set.ID)
    g.title = "Properties_API"
    g.Put(gID)
    g.Active = gID
    v.Group = gID
    v.Put(viewID)
End Sub
hi Rcatania
Thank you so much for your Code. It helped me in getting the changes
srini
