API - List intersecting curves
I'm looking for a method to list all intersections (curves) of a surface model.
basically I want to select all the surfaces and then list all of the intersection curves.
I know how to select the geometry and how to return values to the messagefield.
But what can or should I use to retrieve all the intersecting curves?
while scrolling through the api.pdf I found the 'feCoordSurfaceIntersect' function.
However, this requires a nested-loop where every curve is compared with every surface.
Or is this the way to go?
Maarten Elings | Mechanical Engineer
Re: API - List intersecting curves
Solved it myself by first finding all of the intersections (and their Elements) then subtracting all of the FreeEdge-Elements. and finally sent this resulting Element set to a new group.
