API error with User Dialog
I made an API which uses a User Dialog. I added a Cancel button to my dialog box and if I run the API and click this Cancel button, I have the following error:
API Error (Line 10): (10031) User pressed cancel.
 -->    Dialog dlg
Here is a part of a my API:
Sub Main
    Dim App As femap.model
    Set App = feFemap()
    Begin Dialog UserDialog 400,203 ' %GRID:10,7,1,1
        CancelButton 200,140,140,35
        OKButton 50,140,130,35
    End Dialog
    Dim dlg As UserDialog
    Dialog dlg
End Sub
Could anyone help me on how to use the cancel button ?
Thanks !
Re: API error with User Dialog
The Dialog function returns a value, since your code is not processing this, it's letting you know via the Error.  If you collect the return code, it seems to work fine -
Sub Main
    Set App = feFemap()
    End Dialog
    rc = Dialog( dlg )
    Select Case rc
    Case - 1
        Msg = "User Pressed OK"
        App.feAppMessage( FCM_NORMAL, Msg )
    Case 0
        Msg = "User Pressed Cancel"
    Case Else
        Msg = "User Somehow Did Something Else"
    End Select
End Sub
Thanks for the help Mark !
Hello. Please tell me what is this operator
 %GRID:10,7,1,1
Can't find anywhere description
