API-feFileProgramRun- Undo does not work
we noticed that when API BAS-script is executed from Excel/VS with Femap feFileProgramRun-method Undo won't work. Or works but it skips all the API's run this way and we have lost a quite a lot of work due to this.
This is odd behavior as Undo works as excepted when these same API's are executed from Femap Programming-window.
Any ideas on work-around solution?
Best Regards, Jussi
