Align nodes to coorinate
Anybody know if and how Femap can modify a group of nodes to from one coordinate to another?  For example, if I have 10 nodes that are not aligned, I could tell them to modify the coorinate to 15,, so only the x value is changed and the y, and z are unchanged.
Re: Align nodes to coorinate
Modify - Update - Move To - pick the nodes, enter or pick the coordinates, choose which components to update, in this case, just X.
Mark.
Sorry, I botched the command, it's Modify - Move To - Node.
Mark.
Ok, I get it now.  I missed the purpose of the last pop-up.  It worked with "On Node" and "Locate".  I did not try the others.
Thanks for the help
