Bolt beam Preload NL SOL 106 export Autodesk Nastran
 Hi everybody,
I have a problem with bolt preload export in autodesk Nastran.
In a linear elastic analysis I don't have any problem to export this value but, when I export the same model in a non linear analysis (NON LINEAR MATERIAL MODEL ELASTIC-PLASTIC WITHOUT HARDENING) the bolt preload key are blank.
I also try to paste these card from linear analysis but I this load is not considered.
How can I solve this problem?
Best regards
Stefano
