Centroid in solid
hi,
 i want to create RBE2 element by connecting corner nodes to centroid of the solid ?
please help me how to get centroid point in solid?
regards,
shreeharsha
Re: CG point in solid
Dear shreeharsha,
It's very easy: use command TOOLS > MASS PROPERTIES > SOLID PROPERTIES. Select the solid (please note, the solid should be a GENUINE 3-D SOLID, not simply surfaces!!) and answer YES to the question "Create Node at Total Center of Gravity?". This is your node, simply create a POINT in this node using command GEOMETRY > POINT > METHOD = ON NODE and you are done!.
Best regards,
Blas.
WEB: http://www.iberisa.com
Re: Centroid in solid
Siemens Legend Siemens Legend
Siemens Legend
Here is an API to create a point at the CG of any solid or solids selected.
The HTML Clipboard
Sub Main
    Dim App As femap.model
    Set App = feFemap()
    Dim solSet As femap.Set
    Set solSet = App.feSet
    Dim sol As femap.Solid
    Set sol = App.feSolid
    Dim pt As femap.Point
    Set pt = App.fePoint
    Dim slID As Long
    Dim ar As Double
    Dim vol As Double
    Dim cg As Variant
    Dim inert As Variant
    solSet.Select(FT_SOLID, True, "Select Solid(s)")
    While solSet.Next
        slID  = solSet.CurrentID
        sol.Get(slID)
        sol.MassProp(ar, vol, cg, inert)
        pt.x = cg(0)
        pt.y = cg(1)
        pt.z = cg(2)
        pt.Put(pt.NextEmptyID)
    Wend
End Sub
