Changing the "initial gap" for a plurality of elements GAP
Hello all.
Help option to assign "initial gap" simultaneously for a plurality of properties of the elements GAP
Re: Changing the "initial gap" for a plurality of elements GAP
Siemens Legend Siemens Legend
Siemens Legend
This API should be able to change the "Initial Gap" of each of the Gap properties you have to what you specify.
The HTML Clipboard
Sub Main
    Dim App As femap.model
    Set App = feFemap()
    Dim e As femap.Elem
    Set e = App.feElem
    Dim prp As femap.Prop
    Set prp = App.feProp
    Dim eSet As femap.Set
    Set eSet = App.feSet
    Dim eID As Long
    Dim pID As Long
    Dim newGap As Double
    'set Initial Gap value
    App.feGetReal ("Enter Initial Gap", 0, 9999, newGap)
    App.feAppMessage(FCM_NORMAL, Str$(newGap))
    eSet.AddRule (9, FGD_ELEM_BYTYPE )
    eID = eSet.First
    While eID > 0
        e.Get(eID)
        pID = e.propID
        prp.Get(pID)
        prp.PutValueArray(1, pID, 0, newGap)
        prp.Put(pID)
        eID = eSet.Next
    Wend
End Sub
This script changes the initial gap in all elements in the model. It is possible to add the option of choice of specific elements gap?
Siemens Legend
Here's a few modifications to select which elements you would like to change the initial gap.
The HTML Clipboard
Sub Main
    Set App = feFemap()
    Dim e As femap.Elem
    Set e = App.feElem
    Dim gapSet As femap.Set
    Set gapSet = App.feSet
    Dim eSetGap As femap.Set
    Set eSetGap = App.feSet
    Dim pID As Long
    If eSet.Select(FT_ELEM, True, "Select GAP Elements") <> FE_OK Then End
    eSetGap.AddRule (9, FGD_ELEM_BYTYPE )
    gapSet.AddCommon(eSet.ID, eSetGap.ID)
    If App.feGetReal ("Enter Initial Gap", 0, 9999, newGap) <> FE_OK Then End
    While gapSet.Next
        e.Get(gapSet.CurrentID)
        pID = e.propID
        prp.Get(pID)
        prp.Put(pID)
    Wend
End Sub
