Charting weld
Hello all.
For plotting efforts weld weld elements I could not ask in the diagram on the X-axis position value elements relative CSys. To solve this problem had to renumber all of the elements in the order of selection (Sort Renumbered order by Coordinates also did not work). Can you solve the problem?Charting weld.gif
Re: Charting weld
Given all the options on CWELD elements, there are many that do not have well defined coordinate locations in 3D space.  We're adding calculations in the upcoming FEMAP v11.2 so that CWELD elements will have a coordinate for all FEMAP functionality, including charting.
Mark
