Compatibility between Femap and Solid Edge
Hi to everyone!
I use to draw with Solid Edge and simulate with Femap.
I need to know witch versions of Femap are compatible with witch versions of Solid Edge.
For example, I can normally open a part created on ST9 with Femap V11.4, but witch one is the oldest version of solid Edge accepted? ST7?
There is any information about that? I can't found it...
Thank you.
Re: Compatibility between Femap and Solid Edge
You can see in Femap Help in Geometry Interfaces section, that Femap v11.4.0 support Parasolid 29.0 version (geometry) or Solid Edge ST9 (CAD Software).
If you need to transfer geometry to ST7, you should export it in Parasolid 27.0.
Best regards
Peter Kaderasz
