Create Femap Template/Defaults
I have searched this one without much luck.  I'd like to find a way that whenever I create a new Femap file (File>New) they all look the same with my preferences.  Things like Background color = Black, View Legend Font size, nodes as "x" instead of dots, no magenta profile for contours, etc, etc.
Is this possible to do?  It would save a lot of repeated changes.  Thank you.
Re: Create Femap Template/Defaults
After you set your background color, labels, etc. you'll want to create and save a view, then set that as the default view in Preferences / Views.
This is perfect!  Thank you for the detailed explanation!
