Creating a Model from an Output
Hi all,
I am trying to create a new model parting from a deformed shape (due to thermal distortion). I was wondering if there is any tool in FEMAP that will allow me to do that, or at least to extract the total translation of the nodes I am interested in and then import that again to create the deformed model I am looking for.
Many thanks
Cris
Re: Creating a Model from an Output
I do not know if there is any option but you can do:
- export node coordinates and displacements to data table: x, y,z. Output: results to data table
- define data surface with previous node coordinates and displacements. If you have everything in excel you can copy directly
- assign this data surface to the displacements.
I think it is what you were looking for.
There are several items on the Custom Tools menu that I think do what you want. Go to Custom Tools->PostProcessing. You should see "Nodes Move By Deform" and "Nodes Move By Deform with Options" that will move the nodes based on the results used to deform the active view.
Thanks Jon, although grudy's solution was what I wanted yours was also cool to compare results and learn something new Smiley Happy
Thank you grudy, it was a very clear guide, exactly what I was looking for Smiley Happy
