Curve Accuracy
I was browsing to search for one thing when I came across the mention of changing "Curve Accuracy", but I could not find this option anywhere.  Is this still an option that can be updated?
I've noticed when working with larger models, some of the finer details of curves appear segmented when zoomed in.  When created, nodes/elements generated from these curves appear in the correct position.
Re: Curve Accuracy
Try Tools -> Parameters: Curve Facetting, and reduce the angle errors/chord errors.
Also, for curves of solids: Modify -> Update Other -> Solid Facetting.
