Data Table problem with API
I've been using custom API scripts to extract element output and put it into the data table. My scripts seem to run fine, except after several uses, FEMAP simply stops writing to the data table and displays the message "There are no entities in the Data Table. Select entities to add." The only way I can get it to work again is to close FEMAP and restart. Has anyone else had this problem?
