Determine Node/ Element ID where Max/Min Stresses Occur
Hi Everyone,
I am able to view the max/min streses in the model by going to the View Options (F6) -> PostProcessing -> Contour/ Criteria Style - > Max MIn
I was wondering if there is a way to isolate which elelement/ node the max min stress occurs at.
I know I have to change the Contour Options to Nodal/ Elemental but I am not sure what other option I have to go to.
Saptarshi
Re: Determine Node/ Element ID where Max/Min Stresses Occur
I was searching high and low for this and just found out how:
List > Output > Summary to Data Table...
You will select the output sets, vectors, and nodes/elements to consider and it will spit them out in the Data Table.
