ERROR MESSAGE TRANSLATE
N/A
Hi Guys,
I am a new user of FEMAP and my "big" problem is: the error messages are too much complicated! What I am meaning: when something goes wrong, is too difficult (at least to me) to read and analysis the error message. Maybe if there some "try to do this" (suggestion from software), it can help a lot of the begginer users.
Thank you very much.
Best Regard,
Re: ERROR MESSAGE TRANSLATE
Innovator
Innovator
Hello!,
Probably you are correct, any help to understand better nastran error messages always is welcome!. But is not complex at all, when you have any error open the *.F06 file and look for word FATAL, then you will see there the explanation of the error, ¿OK?.
Also, you have this Bulletin Board ready to help you when you have any problem ...
Best regards,
Blas.
N/A
Hi Blas,
Great! In fact, I try to do this, but it is a quite complicated because the message is not "self explained"...so, you need to looking for the problem.
Innovator
Innovator
Hello!,
Then upload a copy of the F06 file to take a look to the error. Or better try to recreate the error in a small FEMAP model, upload here and we will take a look to it, OK?.
Best regards,
Blas.
