Elemental Non Linear Strain Results
Dear all,
I would recovery elemental strain on shell element in Autodesk Nastran. How can I obtain it?
With  output vector 712 shell max von mises top /bottom, I can recovery nodal strain.
Is possibile to create an elemental strain output vector?
Stefano
Re: Elemental Non Linear Strain Results
Hi Stefano,
In Femap to view elemental results press goto View->View Select-Deformed and Contour Data->Contour Options-> Elemental.
You can also use the post-processing toolbox, expand the contour button and change the type property to elemental.
I hope this helps.
Saptarshi
The problem is that nastran create only nodal results instead elemental
results. I solved this problem updated nastran and modify the output
request. In this way I obtain nodal and elemental strain results.
Thanks for your support
Stefano
S.Milani
