Error for reading Abaqus results using Femap
I wrote the Abaqus results into a "*.fil" file, and tried to open it using Femap. In Femap, firstly, I open "*.inp" by importing "Analysis Models". Then "*.fil" is imported by clicking "Analysis results". The error is always "Line Truncated. Too Long".
Thanks.
Re: Error for reading Abaqus results using Femap
That error message means the FIL file is in binary format.  FEMAP can only read an ACSII version of the FIL or FIN.  Convert your FIL to ascii with the command in the ABAQUS command window:
abaqus ascfil job=jobname
The converted FIL will have the extension FIN.
