Exclude vs Remove
I have a group of elements and nodes.
There are nodes and elements that I want to remove from the group.
I'm confused on exactly what is the difference between the exclude vs the remove operation
I tried them both and they seem to do the same thing.
Any enlightenment?
Thank you
Stressman
Re: Exclude vs Remove
The exclude command permanently excludes an entity from the list. As long as the exclusion is present the entity cannot be placed in the list again. Exclusions must be deleted from the list in order to place the entities in the list again
The remove command removes an entity from the list.
