Export geometry of points and curves
Hello.
How to export geometry consisting of points and curves (solid, surface and no) of Femap in the CAD program (* .dfx)
Re: Export geometry of points and curves
Femap does not export .dxf files. If you are exporting to Autocad, you best option will be to export to IGES using the options as shown in the screen snapshot.
Best Regards,
Chip Fricke
Principal Applications Engineer - Femap Product Development
Another way to go about it would be to place the points/ curves in one group and export only the group.
Saptarshi
