FEMAP API: Going thru SUBCASES
Hi guys,
Im still noobie with FEMAP API and need help...
I'm trying to create a script that needs to go thru every subcase (analysis results) of simulation. Number of subcases is different in each file so I need to somehow count them and activate for each model.
Can you direct me to proper keywords that I should use? I searched a little  and I think I should use:
App.feAnalysisStudy.CountOutputSets
Im having trouble with this function. Do you maybe have some example how to use it?
Re: FEMAP API: Going thru SUBCASES
Try the example script below.
Sub Main
    Dim App As femap.model
    Set App = feFemap()
        'Signed 64-bit (8 byte) Integer
    Dim numb As Long
    'Dim AMngr As femap.AnalysisMgr
    'Set AMngr = App.feAnalysisMgr
        'Create Analysis Study Object
    Dim AStudy As femap.AnalysisStudy
    Set AStudy = App.feAnalysisStudy
        'Loop through all Analysis Studies and Print Number of Results Sets in Each
    While AStudy.Next()
            'Activate each Analysis Study as you loop through
        AStudy.Active = AStudy.ID
        numb = AStudy.CountOutputSets()
        Msg = "Analysis Study: "+Str$(AStudy.ID )+", has "+Str$(numb)+" Results Sets"
        App.feAppMessage(FCM_NORMAL,Msg)
    Wend
End Sub
