FEMAP API Intersect curves/boundary surface
Hi, Is there a way to intersect curves with boundary surface. I could not find a way to even manully do it. I'm running out of ideas, Is there any work arounds? Appreciate any help.
Thank you
Kannan
Re: FEMAP API Intersect curves/boundary surface
Dear Kannan,
Simply convert your boundary surface in Parasolid surface using GEOMETRY > SURFACE > CONVERT command and now you are able to compute the intersection point between point  & surface using METHODS menu :
Best regards,
Blas.
WEB: http://www.iberisa.com
Thank you Blas! Used fesurfaceconvert().
