FEMAP TMG/CFD - effective thermal conductivity
Builder
Builder
Hello Everyone,
I want to calculate effective thermal conductivity on porous structure.
Shall I go for steady state heat transfer analysis or shall I use TMG thermal solver for that.
Any tutotial or advice would be great help for me.
Many thanks in advance.
Re: FEMAP TMG/CFD - effective thermal conductivity
Hello Varun,
Well, unless you want to solve a 3D heat diffusionproblem by hand, or unless your 3D can be simplified to a 2D heat diffusion problem, I would use TMG for that, but still do a steady-state analysis.
From the .log file of the analysis, you can extract the net heat flow across your structure. With the temperatures and the length, you can back-calculate your through-wall heat transfer coefficient.
Hope that helps,
Cheers,
Jack.
Builder
Builder
Thank you jack for the clarification.
Do we have any practical example on how to perform it in TMG.
Hi Varun,
Which version of FEMAP are you using?
Builder
Builder
I am using 11.2.2 version
I suggest you have a look at some of the tutorials available. Just so you know, FEMAP currently runs an older version of TMG (patch 7.5 actually). A lot of improvements have been made since and will be available in the upcoming FEMAP v11.4.FEMAP_Tutorial.pngCheers,
Jack
Builder
Builder
Thank you jack for the help. I will have a look on it.
