FEMAP Trial Activation
Hello all,
I have installed the FEMAP Trial version 11.3.2 and received an activation code. When launching FEMAP for the first time, an activation window appears prompting me to enter said code. I do so, it launches the FEMAPSLU.exe command window. It hangs for a bit, then the activation window comes back again prompting me for the activation code - as if nothing happened.
The FEMAP UI does not open. I've checked the activation code, the firewalls - everything seems fine.
Any suggestions?
Thank you.
Re: FEMAP Trial Activation
Community Manager
Are you trying this with admin privileges?
HI Al,
Yes, and it did not work!
Thanks for the help. I'll close this topic.
