FEMAP stress/Strain paths
I am trying to make a path between two nodes. I have alerady the tool stress linearization that  works for stresses. But if you want to make arbitrary paths. I could find the option and nothing in internet. I am missing something?
I could do it by myself but then I found the following problem. But you have to check  the elements are in the order that you want. You obtain more values for strains/stresses for example per element so you have to choose the value that you need.....
Paths are widely used but I find strange not to find something about it
Re: FEMAP stress/Strain paths
I wanted to add that I have found that NX CAE has this option
I oiund this in the forum
https://community.plm.automation.siemens.com/t5/Femap-Discussion-Forum/Stress-Gradient-Extraction/td...
It may help for the rest of users.Anyway I hope this task will be implemented soon. It is necessary tool to investigate cracks with stress/strain gradients
