FEMAP trial version doesn't response correctly
I installed and activated FEMAP trial version about 10days ago. I was folloing example 11, but the software doesn't respond correctly. For example, after I meshed the longitudinal curves with beams with a  cross section defined, I coud not toggle the cross-sections of the line elements on. Also, after I defined the constraints, I could not show the constraint label, etc. Although, in the message pane, it stated that constraints were defined. I tried to analyze the example, it showed error message.
Does anyone know how to fix this?
Thanks!
Yifan
Re: FEMAP trial version doesn't response correctly
Dear Yifan,
Post your model here, we will take a look to it to see what problem exist.
Best regards,
Blas.
WEB: http://www.iberisa.com
This sounds like an entity visibility issue.  Try opening the Visibility dialog box (press the Ctrl+Q hotkey) and with the Entity/Label tab activated, click the Reset View button.
Press the Ctrl+a hotkey to view the entire model.
If this does not work, please send a screen snapshot of theHelp dialog box (select the Help -> About command and expand it so that all of you system configurations are visible before grabbing a screenshot.  Send the snapshot to me at chip.fricke@siemens.com
Best Regards,
Chip Fricke
Best Regards,
Chip Fricke
Principal Applications Engineer - Femap Product Development
After I uninstalled and re-installed the program, the problem is gone.
But thanks for solutions!!!
