FEMAP works in Demo-Modus only
N/A
I have FEMAP NASTRAN NX Trail Version installed. The License files is saved in C:\FEMAPv1031 as license.dat.
I use Windows 7 32 bit.
The error message is attached.
Thanks a lot.
Corin
Re: FEMAP works in Demo-Modus only
Innovator
Innovator
Dear Corin,
Please read the installation procedure explained here step-by-step https://bbs.industrysoftware.automat...p-Instructions
Make sure you install FEMAP selecting option NETWORK CLIENT, if you select NODE-LIMITED DEMO LICENSE your FEMAP installation will be limited to 300-nodes only.
You do not have to re-install FEMAP, run the batch file "go_network.bat" in the FEMAP directory. Make sure FEMAP is not running when you do this, this will flip the licensing over to Network.
Please update us to see if everything runs fine, OK?.
Best regards,
Blas.
