Fatal Error ... temperature
N/A
Today I downloaded and installed the FEMAP-trial and I'm trying the first analyses with a solid edge part (not synchronus).
Where can I fix following fatal error - I'm actually not interested in temperature-analyses
** USER FATAL MESSAGE 2044 (TA1)
UNDEFINED Temperature set
User information:
The referenced temperature set was selected in the Case Control
but not defined in the bulk data
FATAL ERROR
*** End of job***
Thanks for your help
yours
Petra
Re: Fatal Error ... temperature
N/A
I found the answer myself
Hello, how did you fix the problem?
PieFierro
