Femap 11.2.1 Forward Compatibility
When I attempt to load a FEMAP 11.1.2 database into 11.2.1, the application attempts to create a neutral file first instead of just porting the database.
Is there an inherent forwards compatability limitation for FEMAP?
Stressman
Femap 11.2.1
Re: Femap 11.2.1 Forward Compatibility
Hello!,
This is the normal behaviour when opening an old FEMAP database in newer versions of FEMAP, simply click OK and you are done!.
Best regards,
Blas.
WEB: http://www.iberisa.com
