Femap 11.4 Crashing/Wont Open
Has anyone ever came across this issue.
Quick History:
-11.4 Installed a number of weeks ago, approx. 8 - everything working fine
- After 3/4 weeks said problem has risen, where the programme will not open
- Uninstall & Reinstall removes problem and working fine again
- Further 3/4 weeks problem is back
The following has been tried/already done:
- Ran as Admin
- Firewall check - rules set up
- License server is online and correct
Below is a screen capture of the message I get before it crashes - not the most informative. Any suggestions - apart from un/re install.
Stuart
Re: Femap 11.4 Crashing/Wont Open
Do you use custom start-up view?
In our office, we've seen FEMAP crashes when pointing to custom view library or start-up view.
If using a custom view for start-up, temporarly rename the file (i.e. put a "~" at the begining).
This forces FEMAP to go back to the original startup view.
We've seen it enough here that we don't use a custom view for start-up.  We apply it after FEMAP launches.
I do actually.
I was thinking that it could be some custom item problems - did you experience any other weird issues where it wouldn't open a model unless Femap had a "blank" workspace already in session.
Either way - I will implement loading the view after Femap has opened and hopefully that fixes it (I have already un/re installed it)
Thanks!
We haven't moved to 11.4 yet.
In v11.3.1 I'm able to click and drag models from windows explorer into an empty/blank FEMAP session to open (i.e. from one monitor to another)
No issues now opening a model from a blank workspace or dragging with the view set back to default.
I will update this post - If the problem arises again in a number of weeks.
Stuart_S,
Could you attach your "femap.INI" file?  You'll find it in your femap directory.
[Network]
KeyDir=\\sednt2466\Femap_license$\License_Esplmd.txt
[Femap with NX Nastran]
MWinVarFontFace=Segoe UI
ApiFontFace=Segoe UI
MWinFixedFontFace=Courier New
MWinBkgndColor=149
DynMaxMin=1
RotateAtCursor=1
PickFrontMethod=2
SnapMethod=2
FastDeleteOutput=1
AMMGeomScale=1000.
RemDlgPos=1
NasOutputLocation=2
NasScratchLocation=2
NasOutputPath=E:\00 PROJECTS\~~FEMAP_OUTPUT
MaterialLib=C:\FEMAPv1011\mat_eng_mm-N-tonne-degC-Watts.esp
ViewLib=C:\Program Files\Siemens\FEMAPv114\view.esp
DiskModelScr=E:\00 PROJECTS\000 SCRATCH
This is how it looks now after the reboot, before when I was looking at it during the crashes the view had a callout to load view = 2
Good reminder by RCatania.
You can edit the opening/startup view in the "femap.INI" file.
Forgot to mention, it would also be helpful if we could see your "view.esp" file.
[Network]
MWinBkgndColor=149
DynMaxMin=1
RotateAtCursor=1
PickFrontMethod=2
SnapMethod=2
FastDeleteOutput=1
AMMGeomScale=1000.
RemDlgPos=1
NasOutputLocation=2
ViewDefault=3
As a test, I edited the .INI file to callout a view that didnt exist hoping that it would crash, but it starts up on default no problem
