Femap API Selection Order in Renumber function not available
  I am trying to write a API to select many nodes using the standard selection dialog box. Then pasting them into an excel file in the order selected. Problem is that the nodes are not stored in the order selected in the array.
  Can someone tell me how to access the selection order for nodes stored by the standard selection dialog box? Or a work-around.
-Eric
Re: Femap API Selection Order in Renumber function not available
Use a sortset instead of a set, it does exactly that.
Sortsets do nt have as much functionnalities as sets, so it often becomes useful to manipulate both in parallel. More info in the API: 4 FEMAP Tool Objects > 4.7 Sort objects
Adrien
Code snipet example:
    Dim s As femap.SortSet
    Set s = App.feSort
    s.Select(FT_NODE,False,"Select ")
    While s.Next
        App.feAppMessage(FCM_NORMAL,CStr(s.Current))
    Wend
Thank you astrium_tls (Adrian). That worked perfectly. Expanded my sight into sortset too.
Eric,
Aerospace Stress Engineer
