Femap Beam List Axial and Total Shear - API
Hi
I am requesting the Cbeam element axial and shear forces using the Femap API from custom Tools-> Post Processing->Beam List Axial and Total Shear.
This API is printing the Axial and Shear forces for all the beams in the model based on the following calculations.
I am using Nei Nastran and when I looked into the API code it says
    rc = ouVec1.Get( 3018 ) 'Beam Shear 1
    rc = ouVec2.Get( 3020 ) 'Beam Shear 2
    rc = ouVec3.Get( 3022 ) 'Beam Axial Force
    Dim feElem As femap.Elem
    Set feElem = App.feElem
    While feElem.Next
        If feElem.type = FET_L_BEAM Then
            shear1 = ouVec1.value( feElem.ID )
            shear2 = ouVec2.value( feElem.ID )
            axial = ouVec3.value( feElem.ID )
            totalShear = Sqr( shear1 * shear1 + shear2 * shear2 )
            Msg = "For Element " + Str$(feElem.ID) + " Axial, Total Shear " + Str$( axial ) + " " + Str$( totalShear )
            rc = App.feAppMessage( FCM_NORMAL, Msg)
https://knowledge.autodesk.com/support/nastran/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/NSTRN...
I assume it should be 3018 and 3019 instead of 3020 for shear calculation.
    rc = ouVec2.Get( 3019 ) 'Beam Shear 2
Any Comments
srini
Re: Femap Beam List Axial and Total Shear - API
srinir,
This API was updated for Femap 11.0.0.
Rem File: ListBeamAxialandTotalShear.BAS
Sub Main
    Dim App As femap.model
    Set App = feFemap()
    Dim ouSetID As Long
    Dim ouVec1 As femap.Output
    Set ouVec1 = App.feOutput
    Dim ouVec2 As femap.Output
    Set ouVec2 = App.feOutput
    Dim ouVec3 As femap.Output
    Set ouVec3 = App.feOutput
    Dim feView As femap.View
    Set feView = App.feView
    Dim viewID As Long
    Dim totalShear As Double
    Dim shear1 As Double
    Dim shear2 As Double
    Dim axial As Double
    rc = App.feAppGetActiveView( viewID )
    rc = feView.Get( viewID )
    ouSetID = feView.OutputSet
    ouVec1.setID = ouSetID
    ouVec2.setID = ouSetID
    ouVec3.setID = ouSetID
    While feElem.Next
            rc = App.feAppMessage( FCM_NORMAL, Msg )
        End If
    Wend
End Sub
Hi Catania
Thank you so much. I am using the Femap 10.0.2. Forgot to mention in the post
srinivas
