Femap - Pasting entities values in to selection box/Window
I have a bunch of nodes where probably rigid body motions are occuring and thus analysis is not able to complete successfully. I want to view all the nodes simultaneously in the model.
I was able to get all the node numbers list next to each other seperated by commas, but Femap is not accepting that format in the Window->Show Entities->Nodes selection window. Currently, I have to manully type in the node numbers and I have a bunch of them which makes it tedious. Just wondering if there is an alternative quicker way to accomplish the above?
01.PNGIs there a way to paste multiple entity/node numbers directly in to selection window panel?Is there a way to paste multiple entity/node numbers directly in to selection window panel?
Also, please consider this a request if such feature is absent in Femap i.e. ability to paste entity numbers directly in to the selection box.
Re: Femap - Pasting entities values in to selection box/Window
You're close...
In selection box click on "Pick" then "Paste"
Remember that at any time you can hit "F1" for help in any dialog box.  From the help file:
I think your can paste nodes list into excel and use the row and column swap function of excel ,then copy the colmun to femap dialog,please see the following fig:
Thx EWiener...thats exactly what I was looking for! Will try it out...
Doesn't work that way
