Femap Submodeling
Dear @BlasMolero,
I try to apply a submodel approach as you youtube video
https://www.youtube.com/watch?v=srrwLDtrRlA
I replicate all step but I obtain this result:
DetailDetailSubmodelSubmodelinitial modelinitial modelwrong result stress/displacement distributionwrong result stress/displacement distribution
I see that the imposed displacement reducing by the  external lateral region and are minimum in the middle plane. Why obtain this results? where I'm wrong.
Thanks Blas
Best regards
S
Re: Femap Submodeling
Hello!!,
Your global model has a too coarse mesh, refine a little and the local vonMises stress results will improve, sure!.
Another problem could be the nastran flavour you are using, is not NX NASTRAN then I don't know if the procedure would apply the same way as I have done in the video.
Best regards,
Blas.
WEB: http://www.iberisa.com
Dear Blas,
thank for your quickly response.
I'll try to reduce the mesh dimension of global model. I use Autodesk Nastran for the numerical resolution.
I think (and I hope) that don't make meaninful change with NX nastran.
You know something about this?
Thank again and good work
Stefano
Dear @BlasMolero,
I try to reduce the mesh size of the global model, and I obtain this results:
Stress DetailStress Detail
The quality and the stress distribution are improved.
Thanks again and good work.
Stefano
