Femap.ini File
  Is it possible to put an environment variable "as value" for CustomToolsPath in the femap.ini or it needs to be the full path?  It be easier to share the company APIs.
Frédéric
Re: Femap.ini File
Unfortunately that is currently not possible, however you might be able to approach this another way. Depending on your network configuration and what you need to do, it might be possible to have everyone use the "Map Network Drive..." capability in Windows to make a central API directory look like a drive letter... say "X:\". Then you would just specify "X:" as the CustomToolsPath.
Re: Femap.ini File
Thanks George. This is what we have currently. Is there a plan to have 2 "custom tool"? One for the default Femap tools and one for personal / company?
Fr?d?ric
Re: Femap.ini File
It is a request that we have had for some time but have not gotten to so far. I will look into seeing if it can be implemented for v11.3
Re: Femap.ini File
This should be in FEMAP v11.3
Re: Femap.ini File
Thanks George,
Frédéric
