Femap material library.
Hello. I want to create own library of materials. Tell me where I can find a description of the structure of the file .*esp (what does each number). Sorry for my English.mat.jpg
Re: Femap material library.
Same as a material in the FEMAP Neutral File.  The neutral file format is documented in neutral.pdf the /pdf directory in the main directory where FEMAP was installed.  Materials are Neutral File Data Block 601.
Mark.
Thank you Mark. The file is found. Defined with all the numbers.
