Femap not recognizing Surface Mesh Point
I have introduced various surface mesh points during feature removal but Femap is not recognizing them.
As illustrated above.
Is there anyway I can make Femap recognize these points during meshing? What can I have done wrong? I've had success with this feature on various occassions in the past. So, suprised with the outcome this time.
Re: Femap not recognizing Surface Mesh Point
Post a portion of your FEMAP model here and we can take a look to it.
Remember, before meshing you need to use command Mesh, Mesh Control, Mesh Points on Surface... to define specific locations on a surface where nodes will be created when the surface is meshed.
Best regardds,
Blas.
WEB: http://www.iberisa.com
Hi Blas,
It seems like Surface Mesh point works perfectly fine if u apply it on a meshed component.
In addition, I also did what u suggested i.e. associate points on surface as mesh points and I had desired results.
THanks for the pointers
