Freebody Interface Loads/ Applied Loads Summation Location
 I was given a pressure profile (PLOAD cards) from a customer that was supposed to be mapped to a rough 2D mesh I had created in FEMAP. It is a distributed pressure with different pressures applied to each corner of each quad element. I am trying to back out the resultant applied load/ center of resultant applied load for the model. When I use FEMAP's freebody/interface loads tool, it generically applies the applied load to the center of the nodes. Is there a way to force FEMAP to give the center of applied load?
