Function to copy a property
Is there a function to copy/modify a property. I want to copy a spring/damper property and modify the axial stiffness value thru an API.
The following helps to create a property, but i'm struggling to copy an existing property by selecting an element. Appreciate any kind of help. Thanks
PropID = P.NextEmptyID
P.title = "Caterpillar"
P.type = FET_L_BEAM
P.flagI(1) = 5
P.pval (40) = RAD
P.ComputeShape (False, False, True)
P.matlID = matID
P.Put(PropID)
Re: Function to copy a property
Dear Krish,
To copy property, you need to use Prop Get Method, modify data and Put property with another ID.
Here is small example which copies property with ID = 3 and modifies title and pval(40):
Sub Main
    Dim App As femap.model
    Set App = feFemap()
    Dim propIdToCopy As Integer
    propIdToCopy = 3
    Dim beamProp As femap.Prop
    Set beamProp = App.feProp
    'get all data for property ID = 3
    beamProp.Get(propIdToCopy)
'update properties you want
Dim rad As Double
rad = 0.01
beamProp.title = "Caterpillar"
beamProp.pval (40) = rad
'store property with new ID
Dim propId As Integer
propId = beamProp.NextEmptyID
beamProp.Put(propId)
App.feViewRegenerate(0)
End Sub
Yarko
