Glue Contacts PostProcessing
Analyzing a model with steel screws screwed into aluminum blocks. Used Glue contacts to connect the screws to the aluminum blocks.
How do you PostProcessing the contacts to determined whether the screws will tear the thread and pull out of the aluminum blocks?
