Grounded CBUSH Elements
I currently have V11.2, but am working for a client with only V10.1.  In V10.1, there is no tool for autocreating grounded CBUSH elements.  Is there a .prg available to download that can be added to the custom tools drop down that will enable this element creation in V10.1?
Re: Grounded CBUSH Elements
Hello!,
If the API do not exist in FEMAP V10.1 (it surprise me!) simply send by e-mail a copy to your customer of the API from FEMAP V11.2. directory: go to C:\FEMAPv112\api\Meshing directory and copy the API "Create Grounded CBUSH elements.BAS" (rename to TXT to avoid problems with anti-virus). Ask your customer to copy the file to the API/MESH directory (rename back to *.BAS), and you are done!!.
Best regards,
Blas.
WEB: http://www.iberisa.com
